Results 1 to 10 of 10
Thread: Flow Master Help!
    Patrick Guest
    Flow Master Help!
    I put flow masters on my MM awhile back. I luv the sound and it has some more punch to it. But here is the problem. After about a month I started to get an anoying rattle from the rear end, buzzing noise! I took it back and he said when tail pipes heat up they move a bit. So I when back again when the rattle came back and he said it wasnt the flowmasters, must be sumtin else!
    Is thier anything I can do to fix this prob or what?????
    Mar 2002
    Round Rock, TX
    If it primarily happens while the engine is under load or coming out of a load, but doesn't happen much if at all at idle, I'd bet that one of the baffles in the muffle busted a spot weld.
    Long Island, NY
    I agree a defective muffler can give that sound.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    TripleTransAm Guest
    Sometimes a clamp loosens and the slip-fit contact between two pipes rubs as the car hits bumps, etc. especially noticeable when the exhaust is warm. Being a long set of tubes, this friction at the slip-fit can get amplified along the tube and appear to originate from a different location, usually at the end of the exhaust pipe itself.
    I just finished clearing up a similar problem on my WS6. I have the '98 specific single outlet muffler (driver's side) to which I added an unmuffled identical passenger's side tip. Over the years, the single intermediate Y-pipe-to-muffler pipe's clamp managed to loosen, and when things got hot it would result in a nasty metal-on-metal squeak/rattle that was extremely noisy and seemed to come from the passenger's side extreme rear, even though the clamp sits about even with my waist.
    It took me several weeks of inspecting shock bushings, control arm bushings, muffler hangers, panhard rod bolts, gas tank straps... took apart the whole back end of the hatch interior, ripped out the spare and all hardware, even had the speakers out. Finally, I noticed a little play in the intermediate pipe slip joint as I was manually rocking the exhaust system by its tips.
    So, all this to say it might be a good idea to check all slip-joints for proper tightness when heated up, and don't limit yourself to the muffler area or where it seems to be making noise... don't be afraid to look upstream.
    Orlando, Florida
    I know on the Imps there are heat shields around the fuel tank that can get loose and start buzzing or rattling...
    hth
    2007 BBB Dodge Magnum SRT8
    2003 BBB Crown Vic Sport LX
    1996 BBB Impala SS
    1972 Chrysler Newport
    NOW a MOBIL 1 sticker!!! but running Amsoil.
    My sort of a web page:
    http://www.cardomain.com/id/uwsacf
    TripleTransAm Guest
    The mention of rattling heat shields reminded me of the time my GTA's catalytic converter died. It made a hollow sort of rattle that was hard to track down, until I got under the car and (with exhaust cool) pounded the cat with my fist and narrowed down where the rattle was coming from.
    Most modern cats are made of one or more "bricks" that look like a bunch of really long drink straws stacked one on top of the other, side by side... as they would look in a full box of straws (except they are not round but honeycomb shaped). For several reasons (lean overheating, excess fuel detonation, impact from road debris, etc) the brick may break up and a chunk or two may rattle loosely inside the converter. In some cases, the broken chunk may be expelled out the back of the converter and end up in the muffler, or may rotate internally and end up blocking exhaust flow.
    Oct 2002
    Dallas
    Patrick, 3TA is right, with the exhaust cool and you under the car
    either use your hand or a soft mallet to hit the muffler, cats and
    pipes. If something is loose you will usually hear it rattle. I have the Flowmasters too and so far no problems.
    Ex Marauder owner,
    May 5th, 2003, March Bought new
    February 2007, Installed Trilogy,
    March 30th, 2011, sold to a great home.
    Great car, great people, great times, wonderful memories.
    Patrick Guest
    Thanks!! But another quick question. If it is the muffler, should I take to dealership or go back to where I got the flomasters put on???
    And it is an inconstitant rattle. Fine on start up. Drive normal for awhile (5 min or so) sometimes starts. When it does give it gas at idle and goes away. The same when I decide to play hard. Does this help?????
    Oct 2002
    Milwaukee, Wisconsin
    Lightbulb Buzzing noise
    Patrick,
    I developed a buzzing noise on my MM while I wass in Colorado. It happend while the car was under load going from 2nd. to 3rd. I'll check my mufflers when I get a chance but please keep us informend of your findings. Thanks,
    Tim 49
    Tim 41
    Retired July 1, 2006
    "Somewhere Everyday We Fight For Life"
    2003 Mercury Marauder
    1. 300B (Pre-decontented)
    2. Born November 11, 2002
    3. Adpoted March 13, 2003
    4. 5945 of 7839
    1. 6 Disc CD Changer
    2. Factory Spoiler
    3. Sylvania Silverstars
    4. Escort Passport 8500 Radar Detector
    5. Pioneer TS- A6870R 3-Way Speakers
    6. Bob White Ruby Red Reflectives
    7. Mercury godshead steering wheel emblem
    .820 R/T, 15.356 1/4 Mi @ 92.42 MPH May 2003
    .792 R/T, 14.748 1/4 Mi @ 95.27 MPH Oct 2003
    1996 Ford Explorer XLT 5.0 V-8 AWD Mocha Frost/Saddle. Inservice May 15, 1996, retired October 2, 2004.
    2000 Ford Crown Victoria LX HPP 4.6 V-8 Harvest Gold/Medium Parchment Leather. Born July 25, 2000. Inservice August 29, 2000, retired March 13, 2003.
    2004 Mercury Mountaineer Premier 4.6 V-8 AWD Black/Midnight Grey Leather Sport. Born Jan 29, 2004. Inservice June 1, 2004, retired July 26, 2006.
    2006 Mercury Mountaineer Premier 4.6 V-8 AWD Vivid Red/Camel Leather. Born Feb 22, 2006. Inservice July 26, 2006.
    Long Island, NY
    I would go back to the muffler shop.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    2012 Kia Sedona Van
    Member # 440
    ----- John
