Ive seen debates before about this. I am going to lower the MM by cutting one coil and lowering the rear .75"
My current setup is the Stainless work long tubes with cats that bolt up to the stock H-Pipe.
I am debating weather or not to swap out the cats with some 3" stainless pipes to gain about 3/8" ground clearance. I figured while I do that I should replace the midpipe and see what gains I get from going from stock H to 2.5" mandrel bent.
This would leave the stock mufflers on back. Also I have gotten my care tuned with the cats on will removing them set the A/F ratio off my much?
