Results 1 to 14 of 14
Thread: Coolant Temperature Sensor
    May 2011
    South Carolina
    Check engine light came on, Autozone diagnosed it as failing Coolant Temperature Sensor, will I be ok to drive roughly 20 miles to work tomorrow before I replace this or will I be flirting with disaster?
    2004 Black MM, 100,xxx
    JLT CAI
    AeroTurbine 2525's w/rear cat delete
    Build Date: 12 May 2004
    Delivery Date: 26 July 2004
    'Well I was movin' down the road in my V-8 Ford,
    I had a shine on my boots, I had my sideburns lowered. With my New York brim and my gold tooth displayed,Nobody give me trouble cause they know I got it made'
    Quote Originally Posted by Timw286 View Post
    Has your car every overheated or run hot? If not you'll be OK to drive it.
    Jul 2009
    NH
    ^ WHat he said. If your coolant is full, no worries. If anything, the pcm may pull timing as a precaution and she may not have as much oomph. Did you pull the connector and reseat it?
    12.073 @ 118.43 (Nitto 555)
    Drag racers prayer:
    May 2011
    South Carolina
    No its never overheated, plus theres fresh coolant in there as well. I did reset it and the light came back on. Thanks for the info.
    JLT CAI
    Dec 2008
    South Carolina
    I should check right now but I'm lazy, If there's a sensor on the tank move it around and try to make it tight. Had the same problem on my svt contour
    Adopted 3/31/11. Sold
    03 300a black #1199
    TERMINATOR SWAP
    430rwhp. Done by mo's
    Sep 2010
    orlando FL
    the sensor is located on the crossover pipe near the alt, but you have 2 sensors the driver side 1 is to the gauge in the dash cluster and the passnger side 1, thats the one the dealer says is the cyclinder head temp sensor is what the PCM reads to work your cooling fan so becareful on which of the sensor has failed! if the temp gauge gives a reading on the dash then the 1 on the left side is still good and right side that the PCM reads from has failed and your fan might not come on while driving!
    ^^^what mercuryed said^^^ Exactly.
    Oct 2010
    Michigan
    Just called three different ford dealer parts desks and they all told me the same thing for the placement of the sensors.
    Driver side gets the switch sensor (for pcm/fan):
    Motorcraft part number: SW-1574
    Passenger side gets the temperature gauge sensor:
    Motorcraft part number: DY-1145
    North Aurora, IL
    Quote Originally Posted by loud2004marquis View Post
    Sweet info. Thanks for posting.
    Sent from The White House on taxpayers dimes.
    DTR + 4.10's + Eaton swap = Wreeeeeeeeeeeeeeedom
    Great quotes!!
    Eat poo poo and die heathen.
    Dealers are infamous for having wrong info, especially about the Marauder. Unfortunately, the factory service manual does not make a distinction between the two, and only peripherally mentions that there even ARE two for the MM. Maybe someone can go out to theirs and unplug the passenger side to confirm that this is indeed the gauge sensor.
    The one works the gauge probably won't throw a code that Autozone could read. I don't think the gauge temp sender is monitored by the PCM.
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Jul 2010
    Guntersville Al.
    I just had a temp sensor go bad. It actuly was reading opposit. When the truck warmed up the sensor read cold. So the PCM made ajustments for cold running. Truck ran bad, and would not restart once warmed up. There are 2 sensors on this truck 1 for PCM and 1 for the gauge. The truck was a 2000 ranger 3.0L.
    It was an honor to have
    my ASS kicked by you!
    Rest In Peace!
    Paul T. Casey
    Oct 2010
    Michigan
    Just got confirmation from the gentleman who bought my brand new coolant crossover tube.
    Driver side sensor part number:
    F77F-10884-AB (SW-5174)
    Passenger side sensor part number:
    F5AF-12A648-AB (DY-1144)
    (I was wrong in my post earlier today regarding the passenger side sensor part number.)
    Apr 2010
    Western Canada
    Thank you for posting this we actually need this info for our cobra swaps.
  1. Adding additional coolant temp sensor?
    By Todd in forum Shop Talk
    Last Post: 11-13-2009, 10:01 AM
  2. Engine Oil Temperature
    By FordNut in forum Shop Talk
    Last Post: 10-19-2009, 02:48 PM
  3. Outside Air Temperature Sensor
    Last Post: 11-07-2005, 02:13 PM
  4. Help- Additional coolant sensor
    By jaywish in forum Shop Talk
    Last Post: 04-25-2004, 11:24 AM
  5. Oil Temperature
    By schuvwj in forum Shop Talk
    Last Post: 01-19-2004, 05:34 PM
