Results 1 to 10 of 10
Thread: License Plate Light Socket Damage - Advice?
    Oct 2004
    Herndon, VA
    Unhappy License Plate Light Socket Damage - Advice?
    This week I noticed that my license plate light was out. I took it apart and noticed that the lamp had partially melted the socket that plugs and twists into the lamp holder. There was black melted plastic particles all over too. The owners manual says the replacement bulb is #168 (4.9W). With the damage, this appears to be too many watts for the application. Has anyone else noted this problem with their license plate light?
    I can't tell exactly which bulb number is the one I pulled out because it is quite blackened. I have a #158 (3.36W) and a #194 (3.8W) that I could use for replacement and I think I will use the #158 to avoid any more damage to the bulb socket. Any comments? I know it won't be as bright but I can't totally wreck the socket.
    I had to do something similar (go to a smaller watt bulb) for the high mount brake light in my TBird because the OEM bulbs had really cooked the interior of the lamp assembly.
    Thanks.
    Jon
    2004 Mercury Marauder, dark toreador red/dark charcoal interior
    Born On Tuesday, May 18, 2004
    Sequence Nos.: 2,991 of 3,214 ('04), 10,829 of 11,052 (total) & 926 of 980 (DTRs) & 1 of 2,000 '04s without moonroof
    Purchased On Friday, October 22, 2004
    Sold On Wednesday, February 29, 2012
    Final Miles = 099871
    6 CD Trunk Changer, Heated Seats, Alternative Auto Performance Tune, Borla mufflers (#40652),
    "Powered By Ford" 2005 Ford GT Coil Covers, Aeroforce OBD2 Scan Gauge, Replacement Autometer Oil Pressure Gauge,
    McGard Wheel Locks (#24130), 2005 oil filter drip deflector
    Oct 2010
    very common on any car with a incadesent bulb, head to the bone yard search for another that hasnt been toasted, and get an led bulb problem solved!
    bulb type is a 194
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    I have 194 LED bulbs that will work.
    Aug 2005
    Macclenny, Florida
    Quote Originally Posted by jonroe View Post
    Thanks.
    Jon
    Is the lamp holder melted?
    If so, I would guess that junkyard CVs and GMs would fit.
    By the way, I wonder how many MMs with your combo of DTR and dark interior, do you know?
    ~Jim
    2004 Mercury Marauder SB
    Oct 2004
    Herndon, VA
    Quote Originally Posted by jimlam56 View Post
    The actual light housing (that you see from the outside) is fine but the socket that holds the bulb is a little melted. I think the socket is still usable if I clean it up a little. But, of course, putting the same bulb back in will continue the damage. Probably an LED replacement is best.
    Don't know the rarity of the DTR/dark combo.
    Thanks.
    Oct 2004
    Herndon, VA
    Can I purchase a couple from you? PM please?
    I had the same problem with mine and it got me pulled over a few times as well for a equipment repair order. I cleaned up mine as well as I could and did switch to an LED bulb. I also sealed up the housing as it was coming apart some so whenever I washed the car it would get moisture in it.
    If it's too bad just get one from a junk yard donor.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Smoke Cloud
    Haven't had or happen to me yet but this is a very common problem.
    I'm going to switch to a LED light when I get around to it.
    The KING of BLING!
    BOOST GETS YOU IMPERSONATED!
    Jan 2005
    Just South of Memphis, TN
    Chart Available...?
    Is there a chart available for changing our lamps (bulbs) out to LEDs..?
    Or does your FLAPS know what to give you...?
    Thanks, Architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    Quote Originally Posted by Architect View Post
    Thanks, Architect
    I have yet to see a FLAPS that has decent white LED bulbs at a good price.
    The bulbs I have hurt your eyes if you look at them too long. Just need to see if they will fit in the license plate housing because they are a bit longer that a typical 168/194 bulb.
  1. fog light bulb socket
    By lscmarauder in forum Shop Talk
    Last Post: 01-31-2011, 08:14 AM
  2. Wanted To Buy Fog Light H1 Bulb Holder/Socket
    By ctrlraven in forum Marauder Parts/Misc. Wanted
    Last Post: 11-30-2010, 08:00 PM
  3. signal/turn light socket
    By Aren Jay in forum Shop Talk
    Last Post: 10-15-2007, 07:59 PM
  4. License plate Light
    By SID210SA in forum Shop Talk
    Last Post: 10-23-2006, 09:31 AM
  5. License Plate Help
    By djmcnary in forum The Lounge
    Last Post: 04-04-2005, 12:52 PM
