Getting the new ride inspected.
I am here: http://tapatalk.com/map.php?cx3d0b
Sent from my iPhone using Tapatalk Panther
From The Farm of The Hackster
64 Corvair 4dr
64 Corvair Conv
65 GTO
77 F250 Camper Special
92 Noch Back Stang FOR SALE
93 Buick LeSabre
01 Wrangler
04 Marauder DTR
The Pnther04 did not pass. Have to tune it back to stock setting.
I am here: http://tapatalk.com/map.php?5nvqs5
64 Corvair 4dr
64 Corvair Conv
65 GTO
93 Buick LeSabre
01 Wrangler
04 Marauder DTR
Yeah NJ is buster on the tunes.....................
Member # 383.
2003 Marauder Black.
Build 8/13/02
Launched 9/28/02
Sold May 16, 2018
#3,646 of 7,839 black '03
Interested if it flies through with the stock tune. Had to get ours tailpipe tested to pass.
The guy I got the MM from told me that all you have to do is tune it back then drive it 50 miles computer needs to run a full cycle before returning to insp station.
I am here: http://tapatalk.com/map.php?vkv0xa
64 Corvair 4dr
64 Corvair Conv
65 GTO
93 Buick LeSabre
01 Wrangler
04 Marauder DTR
I've heard that too but when I went to the States inspection place it failed for the first time in 4 tries. It passed with flying colors 3 times and when the State said "unsupported" everything you fail I was miffed. Took the car to a local shop and they read the OBDll port with a scanner and everything came up "complete". Eventually had a private shop do the inspection and his State machine said fail but his OBDll scanner said everything was working. It makes me believe the States software may have a glitch. That's why I'm interested to see if your car zips right through with the OEM tune or you get failed.
Keep us posted on your results.
you will need to drive it more then 50 miles on it back at stock
Mike
Lineup:
03' Marauder Black 300a purchased with 30,000 original miles 04/2012 /Lidio tune/window tintSOLD
2010 Yukon Denali XL (DD)
02' F250 Reg Cab 4x4 (Beach Rig)
06' STS-V Stock gift for Dad
11' Sienna SE (wife's)
still room for a Marauder??
Boat:
06' Pursuit 28OS (money pit)
I am headed to Yonkers ny on Sunday so I will be putting some good miles on it. So next week I will try again.
I am here: http://tapatalk.com/map.php?atousd
64 Corvair 4dr
64 Corvair Conv
65 GTO
93 Buick LeSabre
01 Wrangler
04 Marauder DTR
If you run the drive-cycle procedure, you may not need to drive so far:
http://www.obd2.com/support/reprog/d..._procedure.pdf
Mine flunked last week in Rhode Island after running 52 miles mixed driving back on stock tune. Put 80 more hwy miles on it the same day and went back. Passed with flying colors.
Below are results of the 1st inspection try...
OBDII Readiness - Fail
Catalytic Converter Efficiency - Not Ready
Secondary Air System - Unsupported
Heated Catalyst - Unsupported
A/C refrigerant - Unsupported
Evaporative Emissions Control System - Not ready
Born 9/25/2003 Adopted Aug 11, 2010
#175 of 980 DTR, #537 of 3,214 2004
Lidio Tune, K&N CAI, 4.10s, FlowMaster40s, SS Braided brake lines, SS Bumper Inserts, Mach 1 Chin Spoiler, Lip Spoiler, Grill & Trunk Badges by Daniel, Audiophile 6L8T18C815FD.
I failed all away around. Every thing unsupported I look forward to seeing if I will pass also. I will give it a week.
I am here: http://tapatalk.com/map.php?l2uvix
64 Corvair 4dr
64 Corvair Conv
65 GTO
93 Buick LeSabre
01 Wrangler
04 Marauder DTR
Good evening everyone I wanted to let you all know how the insp went on my DTR04. Well after driving the car for a few days and put about 115 mile from the last insp that i failed I went to auto zone and asked the guy hook it up on there little hand held computer all codes were good so I went to NJ inspection station and the car past with flying colors. Now getting ready to put it back to the SCT 355 tune that was on it and wake it back up.
I am here: http://tapatalk.com/map.php?hmsdc4
64 Corvair 4dr
64 Corvair Conv
65 GTO
93 Buick LeSabre
01 Wrangler
04 Marauder DTR
Thanks for the update.
I don't even bother with the state sites as I've heard so many people have problems with them and the tunes. I return the stock tune, drive my 70-80 miles in mixed driving (HATING it!!!) and pay my local shop the $49.
Only 16 more years until we can get QQ plates
'03 Marauder - "The Backup" -----> SOLD! Now Marauderless
Adopted June '09
K&N FIPK, Magnaflows, SCT Tune, Steeda Underdrive pulley, EMP/Stewart high volume water pump, intake spacer, Autolite XP104's
4/9/11 Remanufactured Marauder engine installed @ 64,400 miles by GNB Auto Repair, Astoria, NY
Learn from my ignorance....CHECK YOUR OIL!!!
'72 Oldsmobile Cutlass Supreme - "The Hulk"...gone to the great junkyard in the sky
'70 Oldsmobile 442 - "The Keeper"...now alive and kicking
