I was asked to build a transmission for a 2003 supercharged Marauder. Since the car was out of state, I chose a low mileage core from a 2004 Grandmarquis. Transmission was torn down and inspected, I found very limited wear. The case was cleaned and I started assembly. The first thing that needed to be changed was the output shaft, the Marauder uses a long output shaft.
Since the transmission was being installed in a 2003 model car, the correct output shaft ring gear needed to be installed. 2004 and newer output shaft ring gears have 24 extended lugs the output shaft speed sensor reads, opposed to the older style ring gear that has 6 holes. Making this change required the output shaft speed sensor be changed to correct part, the sensor for the new style ring gear is .100" shorter to clear the extended lugs. The new style OEM sensor is also white in color.
The new parts were assembled and new teflon rings are installed.
The direct drum oiling holes are enlarged for improved lubrication.
The intermediate stub shaft is upgraded to a shaft made from 300m alloy.
The mechanical diode one way clutch is upgraded to the newest factory part that has a thicker body and more locking teeth. This updated part is installed using an aftermarket spiral locking ring.
