MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Steering, Suspension & Brakes
Steering, Suspension & Brakes Post your discussions about steering, suspension, shocks, control arms and brakes here!
Reply
Thread Tools Display Modes
  #1
Old 06-11-2018, 07:50 AM
badass mm's Avatar
badass mm badass mm is offline
Senior Member
Trader: (1)
Ride height
Is there any way to adjust ride height on the Mercury Marauder is my 03 seems to sit a little bit higher than my old for just was wondering why that would be
Sent from my SAMSUNG-SM-J320AZ using Tapatalk
  #2
Old 06-11-2018, 07:51 AM
badass mm's Avatar
Senior Member
Trader: (1)
Supposed to say 04
  #3
Old 06-11-2018, 08:25 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
if you still have rear air springs, then yes. Adjust the ride height sensor on watts link in front of axle on driver side. req. 8 and 11 mm wrench. only slide it small distance. 1/4 inch will do about an inch on suspension. have to cycle air ride to get it to change. I can't recall which way to move sensor towards driver side or pass. side, It is best to mark where it is now as a reference.
__________________
  #4
Old 06-11-2018, 08:26 AM
03Rauder's Avatar
03Rauder 03Rauder is offline
Junior Member
Trader: (0)
Hi badass mm,
Are you talking about the air suspension ride height in the rear?
I was doing some searching on here last week regarding lowering the Marauder but still maintaining a nice rake and found some info on adjusting the rear air suspension. For the front I believe people suggested after market springs or cutting the stock springs.
Check out this thread for rear air suspension adjustment. That popped up with quick search on google for "Adjusting Marauder rear air suspesnion"
https://www.mercurymarauder.net/foru...ad.php?t=57787
  #5
Old 06-11-2018, 08:31 AM
badass mm's Avatar
Senior Member
Trader: (1)
How do you cycle the system by just turning the key on correct
  #6
Old 06-11-2018, 09:08 AM
Weißbirke Plünderer
Trader: (11)
read the link in the post above, it tells how
__________________
  #7
Old 06-12-2018, 06:15 AM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
Leave a car door open when your adjusting the switch
If your under the car and move the switch, the car WILL come down and smash you!
Move it towards the drivers side wheel. 1/4 should do it
__________________
04 DTR
03 Black 300A
03 Black 300A
03 C.V. Sport Silver Frost
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #8
Old 06-12-2018, 12:37 PM
blazen71's Avatar
blazen71 blazen71 is offline
I'm Your Huckleberry
Trader: (3)
Or turn the air switch off in the trunk til you're done.
__________________
2004 300A Procharger #0010 P1SC, now D1SC
2003 300A Procharger #0017 D1SC (SOLD)
  #9
Old 06-12-2018, 01:18 PM
badass mm's Avatar
Senior Member
Trader: (1)
So move the switch to the driver side to lower and passenger side to raise is that correct
  #10
Old 06-12-2018, 02:36 PM
Gerry24's Avatar
Gerry24 Gerry24 is offline
Senior Member
Trader: (1)
Hey you go...
File Type: jpg 200FBB4F-4A44-4DBF-B47A-C847B62437CF.jpg (63.2 KB, 41 views)
__________________
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15.
  #11
Old 06-12-2018, 02:42 PM
badass mm's Avatar
Senior Member
Trader: (1)
Thanks everybody went underneath there and did it I put it on jack stands underneath the axle so that I could hear the compressor run and I raised it about inch or so looks better thanks again guys
  #12
Old 06-12-2018, 04:45 PM
I miss whitey here
Trader: (5)
Quote:
That only keeps it from airing up
If a small guy can wiggle up in there with the car on the ground, no jack or stands, it will lower with that switch off.
Best to leave the door open so it won't lower
__________________
04 DTR
03 Black 300A
03 Black 300A
04 SILVER BIRCH NA
  #13
Old 06-13-2018, 09:22 AM
blazen71's Avatar
Trader: (3)
Good to know!
__________________
  #14
Old 06-18-2018, 07:19 AM
1Marauder's Avatar
Senior Member
Trader: (5)
Always best to mark it w sharpie before you move /adjust it, so you have a basis for further adjustments.
__________________
Tune, JLT, FlowMaster 42441 Res Delete, New Nitto 235/255 Bigcarsforever dead peddle & custom SRP peddles, 5 coats Zymoil Titanium, Addco front and rear sway bars, KYBs, 1/2 inch coil cut, Sparts Watts link and Control Arms, Car fixer alignment.
  #15
Old 06-25-2018, 02:54 PM
decipha decipha is offline
Member
Trader: (0)
kinda unrelated but relevant possibly
last week I was with the misses getting some things out of the trunk and when she closed the door the back of the car lowered about 2 inches. I was thinking it was due to the weight we removed out of the trunk and it re-leveling itself. Everything seems to be working fine and no issues but first time i ever noticed it.
Is that normal?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ride height ddog1216 Shop Talk 24 03-28-2015 07:53 AM
My MM Ride Height: Help! Apollo Community Discussion 18 04-13-2010 07:52 PM
Air ride compressor & ride height& EGR Bradley G Marauder-specific Parts for Sale 2 05-24-2008 10:18 AM
air ride compressor & ride height sensor Bradley G Marauder Parts/Misc. Wanted 4 05-19-2008 08:39 PM
ride height seanking01 Shop Talk 9 12-12-2006 10:06 PM
Powered by: vBulletin
