MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 06-12-2018, 08:39 AM
prg333's Avatar
prg333 prg333 is offline
Senior Member
Trader: (0)
04- Marauder-201,410 Dreaded Ticking
I have a 2004 Mercury Marauder with 201,454 miles.
It has the dreaded chatter on start up and
under load and when driving you can hear the ticking. It definitely is the chain slapping around and the tensioners are surely worn out. When idling after driving it is quite noticeable also. I SHOULD have paid more attention when
then chatter started back in march, after I took the car out of it's winter hibernation.. A good mechanic said he COULD do all the work to open up the engine cover. But he is a bit hesitant, bc of the high mileage and he does not know what he might find, once he get in the engine.. He gets $75.00 an hour and thinks it could take 15-20 hours labor not including parts.
The mechanic suggested I DO NOT drive the car bc of the chattering.
I am not handy enough to do the work. Plus I spend a bunch of $$ having the AC cooling system re-done and the right rear axel seal went bad.
So instead of having the work done on my current engine. It was suggested I get a replacement engine with less miles. As it would be cheeper to swap engines. Any suggestions/advise as to where I could get a engine with lower miles. Any members have a Marauder engine, they want to sell?
The mechanic I talked to said one could even get a long block Ford engine and put it in the Marauder.. Any thought on that.
I would hate to have to sell the car now but that might be a last resort.
I live in NY in the Hudson Valley area, 60 min from Rockland County, Wetchester County. Bergan County NJ Area.
Thank you for the advise
  #2
Old 06-12-2018, 09:01 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
it should cost like $1200 -1500 range for labor and parts. find a new mechanic. used motor will be $1500-:3000, plus labor. dont see how that is cheaper
__________________
  #3
Old 06-12-2018, 09:06 AM
prg333's Avatar
Senior Member
Trader: (0)
He seamed to think it was cheeper to drop in a new engine. As if you could get one with less miles, it might last longer then mine at just over 200,000
I know the engine on the Marauder is good. But how may miles realistically can you get out of one.
  #4
Old 06-12-2018, 09:10 AM
Weißbirke Plünderer
Trader: (11)
there are members on here with 250,000 to over 300,000 miles
__________________
  #5
Old 06-12-2018, 09:11 AM
Weißbirke Plünderer
Trader: (11)
lower miles engine, no guarantee that timing chains do nit need done. seen them replacec in the low 100k mile range
__________________
  #6
Old 06-12-2018, 09:19 AM
prg333's Avatar
Senior Member
Trader: (0)
True one could run into the same problem with the chain tensioner problem with another engine
  #7
Old 06-12-2018, 09:35 AM
Weißbirke Plünderer
Trader: (11)
it's a judgement call, spend $2500-4000k for motor and swap or $1500 for timing chains. parts are about $450. depends on your budget, cash avail. is it a keeper, or want upgrade in a couple years etc.
__________________
  #8
Old 06-12-2018, 09:50 AM
prg333's Avatar
Senior Member
Trader: (0)
Once you do all that work with the chains and tensioners. Do people usually do the water pump,Upper and lower radior roses spark plugs and Crank shaft seal plus oil change?
  #9
Old 06-12-2018, 11:44 AM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
15-20 hours to change the tensioners and guides???!! While I haven't done this job myself, that seems way high.
__________________
  #10
Old 06-12-2018, 11:52 AM
Curless's Avatar
Curless Curless is offline
Senior Member
Trader: (13)
Whatever you do, DO NOT start it up again... The noise was your warning, there are plenty of people here that gambled and lost...
__________________
#2941 300A
4.10's, carbon clutches
Marty O Tune
Curless Cure
Widened Wheels
Dead Pedal
Eaton Swapped
Bar tender and maker of:
Christmas in a cup
One Legged Lesbian Kickboxer
Cocka Two
  #11
Old 06-12-2018, 11:58 AM
ctrlraven's Avatar
ctrlraven ctrlraven is offline
BiRDMAN
Trader: (28)
Another member here (Seneca) changed my tensioners and guides in about 8 hrs and that was moving pretty slow, we went out to lunch and taking a bit to burp the coolant system.
https://www.mercurymarauder.net/foru...ghlight=seneca
It was the passenger side tensioner that failed, caused slack in the chain and it ate up the nylon plastic on one of the guides.
__________________
300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2013 Lincoln MKS EcoBoost AWD
2010 Ford Fusion Sport FWD
2006 Ford F-350 SD Amarillo
1989 Ford Mustang 5.0 LXsport
  #12
Old 06-12-2018, 12:08 PM
crownvic97's Avatar
crownvic97 crownvic97 is offline
Senior Member
Trader: (4)
15-20hrs is completely ridiculous, I wouldn’t use that mechanic.
Even if you go get a used engine, you should replace the timing components anyways, so that’s not going to save you any money.
  #13
Old 06-12-2018, 01:21 PM
prg333's Avatar
Senior Member
Trader: (0)
Yes 15-20 hrs seems high. Unfortunately I am kind of stuck, hard to find another mechanic where I am. But I can try. Sadly I have driven the car for longer then I should have with the chatter at start up. Now it makes the noise at idling and driving. I hope hat work could still be done on it, and metal has not collected in the oil pan and traveled around the engine.
I am VEY ANNOYED at myself for not addressing the chattering sooner.
Thank you letting me know about the member who did the work. I can PM him
  #14
Old 06-12-2018, 02:25 PM
Trader: (2)
PM Marty...he used to live near you and perhaps he can recommend someone.
__________________
  #15
Old 06-12-2018, 04:12 PM
martyo's Avatar
martyo martyo is offline
MO derator
Trader: (27)
Quote:
I am PMing him now.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2004 Mercury Marauder ticking issue sloza85 Shop Talk 3 03-09-2016 06:47 PM
03 marauder 75k ticking sound in engine Marauder777 Shop Talk 12 03-15-2012 03:27 PM
Dreaded no start :( Canucksmarauder Shop Talk 14 07-18-2008 11:56 AM
My ticking Marauder... TripleTransAm Maple Leaf Marauders 75 10-31-2003 09:52 AM
Powered by: vBulletin
