MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 11-30-2018, 08:13 AM
freakstatus's Avatar
freakstatus freakstatus is offline
More bark than bite....
Trader: (1)
Axle woes...
Looks like I'll need to replace my axle....Does anyone know if these are unique to the Marauder or will a Crown Vic/Grand Marquis axle work? I heard they might be different due to our air bags vs coil springs on the Vics.
Does anyone know for sure?
Thanks all!
__________________
2003 300A
Built: 10/22/02
XCal2 by Lidio
K&N CAI #63-1111
Steeda Underdrive Pulleys
Stewart EMP Water pump
Stainless Works long tube headers
Random Tech high flow cats
Super 44's
Megs delete tips
OEM Spoiler
Progard
Duplicolor red calipers
20% Tint
14.46 @ 97.08
5799 of 7839
Made in Canada
  #2
Old 11-30-2018, 08:27 AM
jaywish's Avatar
jaywish jaywish is offline
Senior Member
Trader: (0)
They are the same axles.
You can look on http://tascaparts.com/
You can select different cars and years to compare part numbers.
they changed to a 31 spline axle in 2005. Those will not fit without upgrading both axles and the carrier. The 03 & 04 and going back many years were 28 spline.
__________________
03 MM, DPB, Charcoal, 6disk, HS, organizer, spoiler Mods: Z&M arms, silverstars, oil deflector, U-Hall Tranny pan. running stock size Cooper Zeon RS3-G1
X-Car 89 GM LS Colony Park, Mods-> Engine Delete, ss duals, HPP 16" rims, 225-60-16, hella H4 & H1 headlights, large frame 3g alt, rear auto air shocks, hd springs, rear police sway, alum driveshaft, 99 front and 03+ rear brake upgrade, tranny cooler, posi, winter boots= Town Car rims, 215-65-16 Goodyear Ultra GW3 Snows, Kenwood speakers, 93CV stereo.
08 Town Car Signature Limited, HID's Mods>235/55-17 Z rated Cooper Zeon RS3-A, Addco 1" rear Sway, Posi, Compustar Remote Start, floor liners, trunk organizer, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17
  #3
Old 11-30-2018, 10:07 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
car-part.com. Any 2003 and up axle is fine, after mid year 2005 they went to 31 spline axles. The hard part is finding. 3.55 ratio worthy of buying. Makes zero difference if springs or air bags. What's wrong with yours? Maybe you need to find another mechanic
__________________
  #4
Old 11-30-2018, 11:11 AM
jaywish's Avatar
Senior Member
Trader: (0)
BTW when you say axle do you mean one of the actual axles themselves or do you mean the whole rear end is giving problems?
__________________
  #5
Old 12-01-2018, 09:19 AM
Trader: (1)
Ya its the whole rear end, right axle leak at the wheel and the rear diff assembly.. I just found one from a wrecked MM. Bought its entire rear.
__________________
2003 300A
Built: 10/22/02
XCal2 by Lidio
K&N CAI #63-1111
Super 44's
Megs delete tips
OEM Spoiler
Progard
20% Tint
14.46 @ 97.08
5799 of 7839
Made in Canada
  #6
Old 12-02-2018, 07:08 AM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
You could have bought repair bearings for a leaking axle seal / worn axle. I just bought 4 for 2 different cars on rock auto for about 40.00 shipped.
The repair bearing relocates the area the bearing rides and where the seal seals on the axle.
Rock auto axles are about $50.00 - $100.00 each
__________________
04 DTR
03 Black 300A
03 Black 300A
03 C.V. Sport Silver Frost
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #7
Old 12-02-2018, 07:59 AM
sailsmen's Avatar
sailsmen sailsmen is offline
Supporting Member
Trader: (1)
OEM "soft" axle syndrome?
__________________
  #8
Old 12-02-2018, 01:16 PM
gdmjoe's Avatar
gdmjoe gdmjoe is offline
Member
Trader: (12)
Post
Quote:
sailsmen - OEM "soft" axle syndrome?
Associated TSB (Technical Service Bulletin) ...
__________________
-click the Vic-
CarDomain Gallery
  #9
Old 12-05-2018, 10:31 PM
IndyMerc IndyMerc is offline
Member
Trader: (0)
the 06, 31 spline axles i pulled from a marquis are noticeably thicker than the 28 spline. They are from every account I have come across great value for the money if not damaged and capable of holding power for the majority of moderately upgraded street machines.
I didn't bother with the aftermarket 31's because guys break those too seemingly often.
I just disassembled my rear end completely, and am waiting to get it back from powder coat to start assembly. PM me anytime.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
9" axle parts, soon to be Marauder axle lifespeed Shop Talk 41 03-20-2016 12:25 AM
Help AC woes Super-Merc Shop Talk 4 11-18-2005 08:00 AM
GM's woes. Embassy The Lounge 4 03-30-2005 10:23 PM
G M woes? Bobby Clobber The Lounge 10 03-22-2005 10:02 AM
More TSB Woes rkk Shop Talk 8 08-17-2003 10:33 AM
Powered by: vBulletin
