Page 1 of 5 12345 LastLast
Results 1 to 15 of 70
Thread: Sagging Bumper?
    Dave G Guest
    Question Sagging Bumper?
    I was just wondering if anyone has noticed a sagg in the middle of their rear bumper cover down at the most bottom edge toward the ground. I have an '04 that has this condition and was wondering if it is normal for the Marauder's to have this. I've looked at some Crown Vic's that don't exhibit this condition. Is it just my Marauder or do they all look this way?
    Quote Originally Posted by Dave G
    Unfortunantly this is a common thing with these cars . they look good when you buy it but when it comes homes and starts getting spoiled with the expensive gas and detailing it starts getting a little heavy in the butt.it still a great lookin a$$ though
    i know there was another thread about this in here and i'm not sure if there was a remidy for this in there as well..i'll have to look...
    MARAUDER S/C Guest
    I would have to agree that the rear facia could use some more support. Maybe Mack and Zack could help us?
    Oct 2003
    Trenton, Michigan
    Rear Fascia Sag
    The rear fascia on mine had a permanent center sag from Day One.
    However, the sag has not worsened in 7 months of ownership.
    In my view, an additional (factory) support clip would have remedied the sag.
    Jun 2002
    I think it's part of the design
    You can't compare to a CV, the rear bumbers are completely different
    I added a bracket to mine. At high speeds, it really bows out and flops around a lot. (in the original bracketless configuration)
    north nj (Planet Houston)
    mine too, i was wondering the same thing when i compared it to troopcar's...hers was doing it too so i assumed it was supposed to look like that.. awh well.
    Oct 2003
    North Richland Hills, Texas
    FordNut, Do you mind telling us how you installed the bracket? I have the same problem on my new '04. It seems worse then the '03 ever did. Thanks! Bill
    Haven't had this much fun since my '63 T-Bird!
    Proud Member of Walker Racing
    Black 2003 300B - Adopted 5/20/03-Left home 4/6/04
    Silver Birch 2004
    Born 01/07/04-Adopted 04/06/04
    Texas Legal Window Tint
    SS Inserts
    GOD'S HEAD GRILL Badge by Daniel
    GOD'S HEAD REAR Badge by Daniel
    Custom Coil Covers w/Button Caps by Daniel
    Oil, Brake Fluid, Power Steering, and
    Coolant Caps - all by Daniel
    Fender Badges
    K & N FIP Kit
    Pro-Guard
    KDW2 Tires
    Cruzer's Arm Rest
    ScanGaugeII with Upgrade
    SCT Tuner program by D/R
    Orlando, FL
    Quote Originally Posted by gilby04
    Sounds like a "Bra" needed on the rear end also to keep it from saggin.
    Oct 2003
    Trenton, Michigan
    Quote Originally Posted by merc406
    Okay, merc, it's likely your recommendation would provide the much desired "uplift" ! I was unaware that sagging rearends were so widespread ???
    Quote Originally Posted by Rollin'Thunder
    I'll try to take some pics tomorrow.
    Cedar Lake, IN
    Quote Originally Posted by MarauderMark
    they look good when you buy it but when it comes homes and starts getting spoiled, it starts getting a little heavy in the butt.it still a great lookin a$$ though
    I had a very similar issue at counseling during my first marriage...........
    Oct 2003
    Beaufort, SC
    I made a bracket out of 1/8" aluminum 1.5" wide and attached it to the frame much like the ones on either side near the exhaust outlets!! Not wishing to drill any holes I contoured The bracket to the inner shape of the fascia and used double sided body moulding tape....So far it is fine and no sagging!!!
    BTW...That sag was the first blemish I saw when I picked the car up.....Couldn't believe the engineers let that one get by!!!
    If anyone is interested I will take photos and attempt to post??
    The fix cost me all of $2.00!!!!
    Marauderjack
    Dave G Guest
    Marauderjack
    Marauder Jack , If you could post pictures of your bracket that would be great. I was thinking of making a bracket if this sagging was normal. Really like the idea of the tape instead of screws. Thanks!
    Mar 2003
    Dearborn, Michigan
    Response from Jerry Barnes
    Yep, I have a sagging rear end also. I am taking back to the dealer next week. Looks like *****!
  1. Crown Victoria rear bumper cover fit on Marauder?
    By studio460 in forum Community Discussion
    Last Post: 03-03-2004, 08:42 PM
  2. Paint problem - back bumper cover
    By Mark McQuaide in forum Shop Talk
    Last Post: 03-03-2004, 03:22 PM
  3. Help-Solid rear bumper not available to us???
    By warren in forum Shop Talk
    Last Post: 09-24-2003, 08:48 PM
  4. Rear bumper cover pushing out
    By warren in forum Community Discussion
    Last Post: 09-15-2002, 06:44 PM
  5. Wtr. down firewall over Cats. & Rear bumper bulge
    Last Post: 09-02-2002, 01:04 AM
