yep i just fixed mine with the same idea. I used a strip of stainless steel 1" wide with a 1/8" lip and double sided tape. so far so goodOriginally Posted by Marauderjack
Matt Creager
#1
-03 Black-
Build date 5/30/2002, purchased12/10/2002, trunk org.Denso plugs,180 thermo,DR exhaust,DR tuner,Addco rear sway bar,Flowmaster 40 series, 2 1/2 exaust, Megs delete tips extended 1" past bumper, FMS 4:10's, Steeda under drive pullies
#2
03 Black 250k miles stock not for long though
this sight is great, but I must with all the good news you learn you also learn the bad like sagging rear bumpers.
I had the same problem at 680 miles in 9/02 --- Ford has a fix for it.
Took it to dealer and they installed a special bracket in the middle
and that solved the problem. No Charge.
WarrenB
Warren - Thanks for the heads up.
2003 Marauder 300B,
Heated Seats
35% Tint
Mercury All Weather Mats
1973 Oldsmobile Toronado
2012 Kia Sedona Van
2008 Corvette Convertible
2021 Prius Prime Limited
Member # 440
----- John
Is there any TSB number or anything we can reference when we take ours in?
2003 Mercury Marauder
2007 Lincoln Town Car
1993 Crown Victoria LX
Anyone else?????????Originally Posted by MARAUDER S/C
I have the same problem with the center saging also the rest of the bumper sags at parts also.
YES I have the same dealOriginally Posted by MARAUDER S/C
Matt Creager
#1
-03 Black-
#2
yup, I have the same thing. not sure if it's sag or horrible fit/finishOriginally Posted by MARAUDER S/C
1 more here. My cover also lacks support.
I created a support for the center sag, my support point is the 1/2" lip instead of from the bottom, invisible unless you go under the car.
The differences are subtle, I did not have a huge sag.
First picture is before.
Next is after.
The support bracket.
Smokie
12.79 @ 107 mph.
TIMESLIPS
Visit my Garage
Yep, I've got the droopy drawers effect also. Never even noticed it until this thread was posted. It looks to be a couple inches off center to the low point. Did someone say that Mercury has a fix for this under a TSB??Originally Posted by Dave G
The wide lip on the under side of the fascia must act like an air pocket or air dam at highway speeds and pull it down distorting the shape permanently without extra mid support.
Originally Posted by Smokie
Smokie...that was a great idea...Mine also had a slight sag...I did mine the same way accept I used plastic ties.
Ray
"87" Grand National
ditto, i just noticed mine sagging too.
2006 GTO. Lingenfelter CAI, V-Max Polished Throttlebody, Vararam TB Spacer, SLP Ceramic LT Headers, SLP High Flow Cats, Custom X Pipe, QTP electric Cutouts, Flowmaster 40 Mufflers, Livernoise Stage 2 Heads and Comp Cam Stage 2 Cam 232/232 .050 @ 114 lsa, custom built transmission with a pro torque 2800 stall. HOPE I HIT LOW 12'S OR HIGH 11'S , CAUSE IM A BROKE MO FO! SOLD
absolutely ingenious
Problem cured!!!
