Page 3 of 39 FirstFirst 1234567891013 ... LastLast
Results 31 to 45 of 571
Thread: Eaton Swap Parts List Thread
  1. #31
    Oct 2009
    Louisiana
    Quote Originally Posted by swordfish View Post
    Also what about the Ider pulley? XR-32-8678-BA
    If anyone needs any more part # let me know I have them.
    Zack, What about the idler pulley? I've been putting all this togather for a couple of months now. I want to have everything for short down time. I was told that we needed the smaller pulley for the bracket. I've not bought this yet so I wanted to double check with you or dave. Thanks
    Mark E. Sword
    1964 Falcon AFX clone (Rommy Hammes)
    1970 1/2 Falcon Cobra
    2003 Marauder DPB #5 of 328
    http://www.mercurymarauder.net/forum...ad.php?t=63629
  2. #32
    You take the smooth idler off the timing cover and install it backwards on the alternator bracket.
    The alternator will need just a small amount of material removed to clear it.
  3. #33
    Nov 2007
    Eastern,Connecticut
    Zack did you find a already made battery cable?do you have a part number for the new battery cable?
    Blower Belt part number?
    2004 Black Mercury Marauder
    2057 of 3213
    Lidio 93 Octane Tune
    4.10 FRPP Gears
  4. #34
    IC pump bracket
    (I made my own)
  5. #35
    Nov 2007
    Eastern,Connecticut
    IC pump bracket
    (I made my own)
    they can use a zip tie
    2057 of 3213
    4.10 FRPP Gears
  6. #36
    Quote Originally Posted by bob6364 View Post
    I wouldnt go that ghetto.
  7. #37
    Nov 2007
    Eastern,Connecticut
    someone posted a pic of a hammered coolant tube under the intake...need that pic .....NM found it
    2057 of 3213
    4.10 FRPP Gears
  8. #38
    Gonna need the EGR delete stuff.
    Here is the 'kit' for those who cant/dont want to make one from scratch.
    http://www.lethalperformance.com/201...te-kit-p-31575
  9. #39
    Oct 2007
    CA
    could yo use the cobra "pulley bridge" (see link)
    http://cgi.ebay.com/ebaymotors/03-04...item3efd0159e3
    Which belt numbers?
    if not, for the "swap brakets": cost? avalibility?
    Thanks!!!
  10. #40
    I'll see if I can find the part number for the pigtail for using the OEM Cobra IAT sensor instead of the Lightning one.
  11. #41
    Oct 2007
    CA
    how about vacuum lines?
    do you need the cobra lines?
  12. #42
    Nov 2007
    Eastern,Connecticut
    Quote Originally Posted by jdenning002 View Post
    no you don't
    2057 of 3213
    4.10 FRPP Gears
  13. #43
    Id like to add this:
    There is a lot of 'webbing' under the Cobra lower intake that can be removed to solve the clearance issue between it and the coolant tube. I never did grind the lower instead of 'massaging' the tube (<<<<<<<LOL) but Im confident minimal if ANY tube mods need to be done if the lower intake is prepped accordingly.
    See pic below:
  14. #44
    Oct 2009
    Louisiana
    Not sure if it helps but I bought the whole harness for 5 bucks more then ford wanted for the plug. I can get the part # when I get home tonite.
    Ford Magnuson Lightning Cobra Intercooler Pump Harness
    intercooler water pump wire harness. Complete it includes fuse, relay and pump connector.
    This harness is used in Magnuson supercharger kits which utilizes a Bosch pump.
    The pump is used on supercharged Ford Lightning and Cobra Mustangs.
    Mark E. Sword
  15. #45
    Oct 2009
    Louisiana
    Ok, so with the smaller pulley you do not have to work on the alternator?
    Mark E. Sword
  1. Eaton Swap
  2. Eaton swap marauder on ebay
    Last Post: 01-31-2010, 02:49 PM
  3. thanks to gortch for the eaton swap brackets!!
    Last Post: 09-07-2009, 04:45 PM
  5. Good start on an Eaton Swap
    By bob6364 in forum Other Parts for Sale
    Last Post: 01-05-2009, 09:22 PM
